พวกพี่ๆรู้คำศัพท์ของ toyota ไหมครับ ลองดูกันนะครับ
Discussion in 'HILUX Club' started by vai, Sep 17, 2008.
  1. vai
    vai New Member Member
    273
    ?Ѿ?????ͷ????ʹ㨢ͧö¹?? TOYOTA
    ABS ( Anti-lock Brake System ) ?к???ͧ?ѹ?????ͤ ABS ???к???ͧ?ѹ??????ö???¡?÷ç??Ǩҡ?????????????Դ?????ͤ?ͧ??? ??зӡ??????º?á?????ö??觺???????????Ҿ??¡??????
    ADD ( Automatic Disconnecting Differential ) ??õѴ??͡??ѧ??ͧ????˹???ѵ??ѵ?
    ???к????????ö????¹??âѺ????͹?ҡ 2 ????? 4 ??? ???ͨҡ 4 ????? 2 ???????????ͧ??شö
    AFS ( Adaptive Front-lighting System ) ?к???Ѻ??????ʧ?˹???ѵ??ѵ?
    ............?к??з?˹?ҷ???Ѻ??????ʧ?˹???ѵ??ѵ? ?¤Ǻ?????û?Ѻ?ҡ???????Ǩ?Ѻ?????٧ ??????????Ǩ?Ѻ??ù?觢ͧ???Ѻ???
    ????ѭ?ҳ ??âҴ????Ѵ?????? ????к??ФǺ?????û?Ѻ?дѺ?㹢?з??ö?ʹ????Ѻ??????͢?????
    Automatic Headlight Beam Level Control ?к???Ѻ????к??ʧ??˭??ѵ??ѵ?
    ............?к??з?˹?ҷ???к???Ѻ????к??ʧ??˭??ѵ??ѵ? ?¤Ǻ?????û?Ѻ?ҡ???????Ǩ?Ѻ?????٧ ??????????Ǩ?Ѻ??ù?觢ͧ???Ѻ???????ѭ?ҳ??âҴ????Ѵ?????? ????к??ФǺ?????û?Ѻ?дѺ?㹢?з??ö?ʹ????Ѻ??????͢?????
    BA ( Brake Assist ) ?к???????ç?á
    ............?к? BA ?зӧҹ㹪?ǧ????ա??????º?á???ҧ?Ǵ???? ??ШЪ?????????ç?á㹡óշ????Ѻ???????º???á?????ç????????§??
    CCS ( Cruise Control System ) ?к??Ǻ????????????ѵ??ѵ?
    ............?к? CCS ?Ъ??¤Ǻ????ѡ???дѺ???????Ǣͧö¹???????????дѺ???????Ƿ???ͧ?????????ͧ????º?ѹ???
    Clearance Corner Sensor and Back Sonar ?ѭ?ҳ??͹??觡մ??ҧ???????????ж????ѧ
    ............?к??зӡ?õ?Ǩ?ͺ???д?ҹ˹???????ѧ ?ͧ?ѵ?ط???ҡ?з??¨????ѭ?ҳ???§?ѧ?????ʴ?ʶҹ??ʴ????ͤǺ???
    DIS ( Direct Ignition System ) ?к??ش???Դ?µç
    ...........?к? DIS ?????ش???Դ??Ш??????ٺ ???ͪ???????èش???Դ?դ??????§?ç???Ŵ????٭?????ç?ѹ俿???ç?٧
    EBD ( Electronic Brake-Force Distribution ) ?к???Ш???ç?á???????Ť??͹Ԥ??
    .............?ӡ?á?Ш???ç?á?????ҧ???˹??????????ѧ ??????ҧ?١??ͧ???????С?âѺ??????㹢?????????? EBD ?з?˹?ҷ???Ш???ç
    ?á???˹?Ҵ?ҹ??????Т?? ????????Դ??????蹤?
    EC Mirror (Electro Chromic Mirror) ??Ш??ͧ??ѧ??Ѻ?ʧ?ѵ??ѵ?
    .............EC Mirror ?Ъ???Ŵ???ź?ǹ?ҡ????з?͹?ͧ?ʧ俨ҡö¹??ѹ??ѧ ?к??л?Ѻ???ʧ?ѵ??ѵ?????ͧ????Ҿ????Ш??ͧ??ѧ
    ?դ????Ѵਹ???ʺ????µ???觢??
    ECT PWR (Power Electronic Control Transmission) ??Է?????? ECT PWR
    ........?к???????ѵ??ѵ? ECT PWR ??????????͹???-ŧ ???????????٧????ʶҹл??? ??觷??????ѧ?Ѻ????͹?ҡ???? ???к??Ǻ???
    ??????????ͧ¹???????????¤ѹ??? ??觡ҤǺ?????????????ͧ¹??ж١?Ǻ????¤????????? (ECU)
    Engine Immobilizer System ?к?????Ѻ??駡?÷ӧҹ?ͧ????ͧ¹??
    ............?к??Ѻ??駡?÷ӧҹ?ͧ????ͧ¹??з?˹?ҷ???Ǩ?ͺ???ʡحᨨҡ?蹪Ծ????ǡح? ?ҡ???ʶ١??ͧ?????????????ͧ¹??ʵ???
    GOA ( Global Outstanding Assessment ) ?ç???ҧ?????? GOA
    ............GOA ??? ?ç???ҧ?????¢ͧ???ö¹????ǹ???????ͧ????÷??١?Ѳ???͡Ẻ????դ?????觢???????駵?Ƕѧö¹?? ??ǹ??????ç ???ҧ??ҹ˹????д?ҹ?????͡Ẻ????ա?ôٴ?Ѻ?ç???ᷡ?ҡ??ê? ??ж?????ç???ᷡ??ѧ??ǹ??ҧ?ͧ???ö ????Ŵ??????????·???Դ??鹡Ѻ??ͧ?????
    HID ( High Intensity Discharge ) ??˭?˹??Ẻ????¡??????ç?٧
    ...........??˭?˹??Ẻ????¡??????ç?٧ ?Ъ??·???????ʧ????????͡?????ʧ???ҧ?ҡ??? ??觪???????âѺ???????ҡ?ҧ?׹??繪Ѵ???
    Hydrophilic Surfaced Side Window ??Ш??ͧ??ҧ???ͺ??û?ͧ?ѹ??????Ẻ Hydrophilic
    ............??????ͺ?з?˹?ҷ?????Ŵ?????е?Ǣͧ?´??ӷ???Ш???з?轹??
    In Car Navigation ?к??ӷҧ
    ............?к??з?˹?ҷ????¹ӷҧ?¼????????ö??˹??ش???»??·ҧ?????Թ?ҧ?к??Ъ??¹ӷҧ??ѧ?ش???????ѵ??ѵ?
    Multi Information Display ???ʴ??Ţ??????????˹?ҷ???ʴ??????š????ҹ????ǡѺ
    1.???ԡ?????س???????¹͡ ????????????¢ͧö
    2. ?????????ͧ????ѹ??????ԧ?????
    3. ?????????ͧ????ѹ??????ԧ ??й??
    4. ???????ҷ????㹡?âѺ???
    5. ???????ҷ??ö????ö??????ա
    Overdrive ( O/D ) Switch Momentary Type ??Է??Ǻ??? O/D Ẻ Momentary
    ............??Է??Ǻ??? O/D Ẻ Momentary ??˹?ҷ?????????????͡?ҡ????????????????ʶҹ??ʴ???? ( O/D OFF ) ??зӡ?ôѺ????ͧ¹?좳з????????????????????????? ?????ʵ???????ͧ??????????????????쿡?зӧҹ?ͧ???ѵ??ѵ? ???????ʴ?ʶҹ????
    Rain Sensor ??????Ǻ????Ѵ??ӽ??ѵ??ѵ?
    ??˹?ҷյ?Ǩ?Ѻ????ҳ??ӽ? ?к?????????ӧҹ?ѹ?շ?? Sensor ??Ǩ?Ѻ??ӽ??? ?·????????Ǣͧ??û?Ѻ??ӽ???????ѹ?졺????ҳ??ӽ???赡??й??
    Smart Key Entry System ?к?????췤???
    ?к?????췤??? ?Ъ???㹡????ͤ?Ŵ??ͤ??е? ??????ͧ??ح????? ?ӡ????ͤ???¡?á???????Է??????ͨѺ??е?
    SRS Air bag System SRS Side Air bag System ?к??ا????????
    ............?к??ا???????´?ҹ??ҧ ?к??ا???????¨Ъ??º???ҡ?úҴ?红ͧ???Ҵ????м??????õ͹˹?? ????ͻ??ʺ?غѵ??˵??¨Ъ???Ŵ?š?з??????Դ??鹡Ѻ˹??͡???????Тͧ???Ѻ??м??????ô?ҹ˹????д?ҹ??ҧ ??觨е?ͧ?Ҵ????Ѵ?????? .
    THS ( Toyota Hybrid System) ?к??κ?Դ
    ???к??Ѻ????͹ö¹??????????ͧ¹????????????????ѹ
    TRC (Traction Control System) ?к???ͧ?ѹ?????ع???
    ?? TRC ?Ъ??»?ͧ?ѹ?????ع???㹢?????????ͧ???;?鹶?????
    TVSS ( Toyota Vehicle Security System) ?к???ͧ?ѹ????
    ............?к??з?˹?ҷ???Ѻ?ѭ?ҳ?Ҩҡ??????Ǻ??? ??觨???˹?ҷ????ͤ?Ŵ??ͤ??е???л?ͧ?ѹ???ʵ???ö¹?? ???㹡ó????к????Ǻ??? ??????ա???á???ö¹??????????öʵ?????
    V.N.T (Variable Nozzle Turbocharger) ?????Ẻ?üѹ
    ?к?????⺷???üѹ?ç?Ѵ?ҡ??????????С?÷ӧҹ?ͧ????ͧ¹??
    VFD ( Vacuum Fluorescent Display Digital Center Meter) ?ҵ??ѴẺ VFD
    ?ҵ??ѴẺ?ԨԵ?? ????Ţ???ͧ?ʧ??????????ȹ??????㹢?С?âѺ???
    VSC (Vehicle Stability Control System) ?к??Ǻ?????÷ç??Ǣͧö¹??
    ............VSC ???к????¤Ǻ????ʶ????Ҿ??ȷҧ??÷ç??Ǣͧö???????????????Դ?????ش?? ??觨з?˹?ҷ??????ѹ??Ѻ?к???ͧ?ѹ?????ع??? TRC ??ШФǺ??????????Ǣͧ????ͧ¹??Ѻ?ç?ѹ????ѹ?á??????? ???????ö????????????͹????㹷?ȷҧ????ͧ???
    VVT ? I System (VVT- I, Variable Valve Timing ? intelligent) ?к?????ŤǺ????üѹ
    ............VVT?I ???к??Ǻ?????÷ӧҹ?Դ - ?Դ?ͧ??????ʹբͧ????ͧ¹??????ըѧ??С???Դ-?Դ???????????Ѻ??????Ф??????Ǣͧ????ͧ¹?? ?????????ͧ¹???ջ???Է???Ҿ㹡?÷ӧҹ?٧???, ?????Ѵ??ѧ?ҹ??????ԧ, Ŵ?ž??, ö¹?????ѵ????觷????????Ѻ???
    Water Dispersing Side Window
    .............??Ш?˹?ҵ?ҧ???˹?????ͺ??û?ͧ?ѹ??????Ẻ Water Dispersing ??????ͺ?з?˹?ҷ?????Ŵ?????е?Ǣͧ?´??ӷ???Ш???з?轹?? ?????????ȹ????????Ф?????ʹ???㹡?âѺ???
    Wide View Outer Rear View Mirror ??Ш??ͧ??ҧẺ Wide View ??Ш???ǹ?????͡Ẻ????? ????ͧ??繴?ҹ??ѧ????ҧ???ҡ??? ??Ъ???Ŵ?ش?ʹ㹡???ͧ??繢ͧ???Ѻ???
    Wireless Door Lock Remote Control System ?к???????͹???
    ............?к??з?˹?ҷ??Ǻ????????ͤ??е? ??????¡?äǺ????ҡ??Է???????????觤????ѭ?ҳ??ѧ???ͧ?Ǻ??? ???͵?Ǩ?ͺ????㹡?ûŴ??ͤ?????ͤ??е?
  2. Hang@HLc
    Hang@HLc New Member Member
    3,018
    51
    สุดยอดครับ ความรู้มากมาย
  3. INTER_ZONE
    7,700
    280
    83
    มีครบเลยอ่ะ...ขอบคุณครับ...
  4. BEN360@HLc
    BEN360@HLc New Member Member
    2,536
    35
    ขอบคุณมากครับสำหรับข้อมูล
  5. โต๋เต๋
    โต๋เต๋ New Member Member
    590
    ขอบคุณคับกำลังต้องการข้อมูลนี้อย่างมากเลย
  6. hivigo
    hivigo New Member Member
    2,219
    ดีๆๆ..ชอบ
  7. joe_non@HLc
    joe_non@HLc New Member Member
    2,833
    ขอบคุณก่อนล่วงหน้า เด๋วกลับมาอ่าน
  8. GAUSS
    4,354
    วิศวกรรม ยานยนต์มาแล้ว
  9. shizu1911
    shizu1911 New Member Member
    225
    ฟามรุทั้งนั้นเยย
