V6 24-valve MIVEC Engine The sophisticated, powerful (200BHP@7500rpm) 2.0-litre V6 MIVEC (Mitsubishi Innovative Valve timing and lift Electronic Control) DOHC engine switches automatically between two sets of cam lobes: one for deft low rev response with muscular yet controlled torque, and the other for execptional top-end power. The result is a silky smooth ride at steady speeds, with a resonant, throaty bass roar that thrills the spirit when you decide to put the throttle down. V6 24-valve Engine The powerful 2.0-litre V6 DOHC engine is almost as powerful as it's sophisticated MIVEC counterpart, with flexible torque and outstanding peak power of 180BHP at 7000rpm (a mere 500rpm lower than the MIVEC unit). The result is a more refined engine note at high are RPM with minimal loss in performance. Like the MIVEC engine the 2.0-litre V6 DOHC engine is most at home at high revs.
Dimensions 1 Front Track 1490 mm 2 Overall Width 1735 mm 3 Wheel Base 2500 mm 4 Overall Length 4365 mm 5 Ground Clearnace (unladen) 150 mm 6 Overall Height (unladen) 1300 mm (1350 mm)* 7 Rear Track 1485 mm * with Sunroof Performance Type Mitsubishi E-DE2A Mitsubishi E-DE3A 1800 16V V6 2000 24V V6 2000 24V Mivec GS GR / GX GPX / GP Version R Max Speed 125mph 136mph 142mph Max Power 125 BHP @ 6000 rpm 180 BHP @ 7000 200 BHP @ 7500 Max Torque 16.5kgf/m @ 4500 rpm 19.5kgf/m@4000 rpm 20.4kgf/m @ 6000 rpm Min Turning Radius 5300mm Engine Type Mitsubishi E-DE2A Mitsubishi E-DE3A 1800 16V V6 2000 24V V6 2000 24V Mivec GS GR / GX GPX / GP Version R Engine Type 4G93 6A12 Valve System and Number of Cylinders SOHC 16 Valve 4 Cylinders DOHC 24 Valve 6 Cylinders Size (mm) 81.0 x 89.0 78.4 x 69.0 Total Displacement 1834 cc 1998 cc Compression Ratio 9.5 10.00 Weights Type Mitsubishi E-DE2A Mitsubishi E-DE3A 1800 16V V6 2000 24V V6 2000 24V Mivec GS GR / GX GPX / GP Version R Kerb Weight 1100 kg 1150 kg 1190 / 1210 kg Seating Capacity 4 persons + Quote Reply
