RacingWeb Community
Car Audio & GPS Forum
ถามหน่อย แอมป์ us thunder ทำไมร้อนเร็วจัง
<p>[QUOTE="zenon_pub, post: 249634, member: 42554"]US thunder amps get hot no matter what you do....even at 8 ohm</p><p><br /></p><p>the only way to make it cooler is to use a fan</p><p><br /></p><p>or</p><p><br /></p><p>put more powerful fets ,higher amperage rectifying diodes, and higher value capacitors in the power supply.[/QUOTE]</p><p><br /></p>
[QUOTE="zenon_pub, post: 249634, member: 42554"]US thunder amps get hot no matter what you do....even at 8 ohm the only way to make it cooler is to use a fan or put more powerful fets ,higher amperage rectifying diodes, and higher value capacitors in the power supply.[/QUOTE]
RacingWeb Community
